It is currently Mon 25. Nov 2024 4:55:00
PostPosted: Thu 20. Jun 2019 21:11:27
I am using a Spektrum IX12 and I have never used the stabilization and rescue together. I only used Head-lock + rescue activated by a momentary switch.
I need help setting up the TX and software so I can switch between stabilization on and stabilization off then be able to use my momentary switch for rescue for either mode. I have another thread that explains what I am currently trying and what the results are. I am using a mix for the rescue. Is there a better way to do this?
Here is the other thread:
viewtopic.php?f=20&t=3348
PostPosted: Fri 21. Jun 2019 2:35:29
SOLVED!!!!!!!
I used a couple AND OR mixes. Now I get the same value of -60 during Rescue for both head-lock and stabilization.
I will go out and fly tomorrow.
Thanks for all the help.
Users browsing this forum: Bing [Bot] and 60 guests
