It is currently Mon 25. Nov 2024 2:37:12
PostPosted: Thu 09. May 2019 21:13:07
I have following configuration:
-Spirit Pro
-HobbyWing Platinum 50A V3
-Taranis X9D
-FRSky R-XSR Receiver
I have connected PRM from HW to PIT from the Spirit Pro.
Now I whant to have the RPM on my Taranis but I do not know how.
I will use the Governor from HW and not the one from the Spirit.
What settings I have to do on the Spirit System?
I couldn't find my anser in www. Hopefully you can help me.
Best Regards
Serenus
PostPosted: Fri 10. May 2019 7:23:21
You have to set the checkbox and activate governor in spirit. Then you can enter the gear ratio, pole counts (sensing divider). After that you can deactivate governor again, safe your settings and it should work just fine.
PostPosted: Fri 10. May 2019 12:34:14
No need to activate Governor. You can set the parameters in the Telemetry window in the Advanced tab.
It is only needed to enable the telemetry there.
In any way you have to proceed according the OpenTX integration guide and connect FrSky integration cable.
PostPosted: Fri 10. May 2019 15:52:13
but the HW Platinum V3 do not have telemetrie. I can olso only choose HW Platinum V4 not V3.
I have no connection to the side connector. I only have the RPM signal from the HW V3 connected to PIT.
If I activate the Govener in the Spirit I can see the under General -> Governor -> Governor -> RPM Meter the Requested and the current RPM. This is working. That means the Spirit gets the current RPM. But how to send this value to the taranis? If I search for telemetrie data I can only find RSSI and RxBT which is working.
@↓ZeXx86: does this mean I can only get the RPM on my Taranis with the Lua script?
PostPosted: Fri 10. May 2019 16:56:39
Do I have to connect the SYS from Spirit with the s.Port from the receiver? does this mean I can't use my bluetooth modul any more?
PostPosted: Sat 11. May 2019 17:07:54
Yes, FrSky integration cable must be connected in any way.
ESC telemetry will be disabled for this ESC, but RPM will be still transmitted. Bluetooth module can be used, but you have to change cable in the SYS port.
PostPosted: Sat 11. May 2019 19:57:50
Hello ZeXx86,
first off all, many thanks to your support. Its getting clearer for me now. I have ordered the integration cable in your shop.
Do I have to create an Y-calbe to use Bluetooth and telemetry on the SYT Port for Red and Yellow cable?
Users browsing this forum: Bing [Bot] and 76 guests
