It is currently Mon 25. Nov 2024 6:46:21
[ 2 posts ] |
Tgilf
Posted: Wed 01. May 2019 20:55:28 |
How can I connect the hobbywing platinum esc 25a v4 to my uSpirit? The esc has a one cable yellow normal servo plug which should be rpm. With receiver connected and esc (throttle) connected to uspirit I don’t have any jst Adapter left, . How is this meant to be done? Thanks Tom
xokia
Posted: Thu 02. May 2019 2:32:59 |
The yellow wire has to connect to the pitch pin of the P/E/A pins.
You can either get a JST connector and cut it then solder the RPM wire to that wire. -> this is what I did because I did not want a giant mess of wires. Oxy 2 I assume? I had the exact same setup.
Or plug the RPM wire into a JST servo adapter. Make sure it lines up with the Pitch pin.
I had telemetry and ext gov on my Oxy 2. To many wires for very little benefit IMO. The ext gov works but I did not find it any better than the internal gov. I actually preferred the internal gov of the hobbywing. Just my $.02
[ 2 posts ] |
Users browsing this forum: No registered users and 41 guests |
