Incorrect swash movements with T-Rex 550L and Graupner MZ-24 https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=3247 |
Page 1 of 1 |
Author: | Spartan2381 [ Tue 02. Apr 2019 3:08:14 ] |
Post subject: | Incorrect swash movements with T-Rex 550L and Graupner MZ-24 |
I'm trying to setup a T-Rex 550L with the Spirit Pro. When I get to the point in the setup to check stick inputs and corresponding swash movements, that's were I'm needing help. Attachment: In the Align manual I have followed the directions in in terms of servo to FC connections:
CH2 Servo -> CH2 on FBL CH3 Servo -> CH3 on FBL Attachment: Here is what I get with stick movements. I'm in the US so Mode 2:
2. Right Stick Right -> Aileron moves to 100% (Servo 1 moves up, Servo 3 moves down, Servo 2 does not move) 3. Right Stick Up -> Elevator moves to 100% (All servos move down) In the MZ-24 Pro radio I have selected swash type of 1Servo/Normal. SUMD is outputting on Channel 8 of the GR-24L RX. Attachment: I think the default channel mapping on radio is: 1. Throttle 2. Aileron 3. Elevator 4. Rudder 6. Collective pitch Do I need to change the channel assignment on either the radio or Spirit? |
Author: | ZeXx86 [ Tue 02. Apr 2019 7:25:18 ] |
Post subject: | Re: Incorrect swash movements with T-Rex 550L and Graupner M |
Hello, the problem is you have used Align manual for servo layout instead of the Spirit. So CH1 servo from Align manual should be connected at the CH2 at the Spirit unit. CH2 at the CH1 port. CH3 at the CH3 port. |
Author: | Spartan2381 [ Wed 03. Apr 2019 5:16:36 ] |
ZeXx86 wrote: Hello, the problem is you have used Align manual for servo layout instead of the Spirit. So CH1 servo from Align manual should be connected at the CH2 at the Spirit unit. CH2 at the CH1 port. CH3 at the CH3 port. Hi @ZeXx86, After swapping the connections per your instructions I'm getting proper movement.
Right stick pushed right = swash tilts right Left stick pushed forward = swash moves up Thank you for your help. Onto to the rest of the configuration. |
