It is currently Mon 25. Nov 2024 8:31:39
[ 2 posts ] |
helimike
Posted: Sun 31. Mar 2019 23:53:23 |
I have created a problem with a red Spirit unit. Connecting a Geo to main satellite port and a satellite in the ruder channel I could not get the sat to bind. I left the system plugged in to computer (mistake) and bind plug in other bind location. The satellite started to heat and burned. I used another Sat after unplugging the system lead and got a bind but now the transmitter will not move any servos in the model. I reset the Spirit unit to factory setting and still no movement of servos. What should I try next?
Thanks for your great support!
Posted: Mon 01. Apr 2019 10:57:24 |
please try to connect the Satellite back to the primary port instead of GeoLink. Do not forget to turn off GeoLink support in the Spirit Settings. Then try to bind it again and check if channels are moving.
[ 2 posts ] |
Users browsing this forum: No registered users and 15 guests |
