It is currently Mon 25. Nov 2024 6:45:33
PostPosted: Fri 12. Apr 2019 12:09:52
I'm just building up a new scale heli:
Regular Spirit, YGE 35LVT connected to the primary sat port and rpm Signal on PIT
RX is a 4649T with signal on AIL and power trough a Y-cable from RUD.
On the second Y-plug is a Spektrum Adapter V2 to feed a second Satellite since the 4649T is the first one.
I can bind the SAT, but I don't see a result in the telemetry. This means I see a zero for antenna A but no display for L or R.
It seems to me, the SAT is fired up but does not deliver anything through his antennas.
What is wrong?? :?
PostPosted: Fri 12. Apr 2019 12:36:09
Spektrum satellite has no telemetry thus it will not change anything at display. It is working just as a backup receiver.
PostPosted: Fri 12. Apr 2019 13:11:41
Do I understand this correct:
If a Sat is on a Spektrum Receiver it shows lost packages in the telemety window.
Ifi the Sat is connected through the Spirit system it does work, but does not report lost packages.
Most important is that the Sat delivers information to the system. :mrgreen:
Thank you for the quick response.
PostPosted: Fri 12. Apr 2019 13:23:30
It is not entirely correct, because the telemetry information is provided by Spektrum receiver, not the satellite itself.
In any way there is nothing wrong. Lost frames are reported in the Spirit flight log.
PostPosted: Fri 12. Apr 2019 13:42:40
OK, if the Sat is hooked up to the Receiver, the Rx collects the missing packages (not fully missed frames) from his and the sats antenna.
When the Sat is hooked up through the Spirit, the receiver can't collect and report the Sat's missing packages. Clear. :idea:
