Help needed , now idea what's wrong https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=3223 |
Page 1 of 1 |
Author: | kwegrzyn [ Wed 20. Mar 2019 16:53:20 ] |
Post subject: | Help needed , now idea what's wrong |
Hi if anyone can help , appreciated Tx Futaba T8J Rx Futaba 2000SB Spirit Pro no S-BUS Settings and wiring Spirit ELEV/PITCH/AIL to Rx channels 1/6/2 Spirit RUD to Rx channel 4 Spirit CH4 to Rudder servo Spirit CH3 to Aileron servo Spirit CH2 to Elevator servo Spirit Ch1 to Pitch servo unfortunately doesn't work ,swashplate irrelevant to stick move . Tried everything nothing work . Any ideas ? |
Author: | ZeXx86 [ Thu 21. Mar 2019 10:56:36 ] |
Post subject: | Re: Help needed , now idea what's wrong |
Hi, if it possible to use the S-BUS then it would be better and easier. Please try to connect also AUX port with the receiver if you want to use the PWM connection scheme. Please do not look at the swashplate yet, but at the Diagnostic tab in the Spirit Settings first. There channel movement should be correct, eventually channel reversing might be needed to obtain correct direction of the movement in the Diagnostic tab. It should be: Spirit ELE/PIT/AIL to Rx channels 2/6/1 Spirit RUD to Rx channel 4 Spirit AUX to Rx channel 5 |
Author: | ZeXx86 [ Wed 29. May 2019 8:34:18 ] |
Can you tell me what receiver it really is, please? Unfortunately I can't find any receiver such as 2000SB from Futaba. If it has 4 ports then it is designed usually for S-BUS. In that case I highly recommend to use S-BUS. Otherwise you will be unable to connect throttle anywhere. |
Author: | kwegrzyn [ Wed 29. May 2019 10:14:07 ] |
my apologize , FUTABA R2008SB |
Author: | ZeXx86 [ Wed 29. May 2019 12:12:32 ] |
Thank you. Then please connect the cables as I have written in the original reply. For some reason you have wired it differently in the receiver. Anyway usage of the S-Bus protocol would be much easier, more reliable, faster and precise. |
Author: | kwegrzyn [ Fri 12. Jul 2019 17:52:16 ] |
so guys , I promise I'm asking for support last time , can you please support me with connections ? S-bus HUB - what should I connect here - 3 servos (pitch/aileron/elev) and then to Rx S/bus slot ? BEC - to Spirit AUX1 ? where should I connect rudder servo ? how should I link Rx with Spirit ? I have 4 servos (pitch/ail/elev/rudder) S-BUS Futaba HUB receiver R2008SB Spirit Pro BEC how all of this should be linked together ? |
Author: | LogoX2 [ Fri 12. Jul 2019 18:05:59 ] |
Spirit RUD to Receiver S-Bus Spirit CH4 to Rudder servo Spirit CH3 to Aileron servo Spirit CH2 to Elevator servo Spirit Ch1 to Pitch servo BEC to Aux 1 |
Author: | ZeXx86 [ Sun 14. Jul 2019 8:38:31 ] |
When you will open the Setup Wizard you can see how to connect the cables exactly - depending on your swashplate. With S-BUS it is much easier and also safer than with PWM. |
