ZeXx86 wrote:
There are two options how to solve the problem:
a) You can use a needle and remove the plastic and put the Telem Kontronik brown wire to the Jeti integration cable.
b) You can get second plastic part and modify the Jeti integration cable. We can send you such plastic housing.
In case of new Telem Kontronik V2 cable this problem will not occur as the cable is using different connector.
Perfect,I will modify the cable and in the future order the version 2 cable.
Thanks for your patience and help it's much appreciated.
Sent from my SM-N950W using Tapatalk
