Frsky x10s and gyro settings https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=3185 |
Page 1 of 1 |
Author: | blarks [ Sun 03. Mar 2019 9:41:45 ] |
Post subject: | Frsky x10s and gyro settings |
I am using an x10s with frsky os not opentx, I have adjusted end points so that the tx gyro and spirit diagnostics match, but when I change gyro in tx 1 increment equals 2 in spirit so for example if I change from0 to 10 in tx spirit goes from 0 to 20. Any idea why it is doing this ois it something I am not doing right or a setting in the tx. Still new to the brand so I may be missing something. |
Author: | ZeXx86 [ Sun 03. Mar 2019 11:19:09 ] |
Post subject: | Re: Frsky x10s and gyro settings |
Hello, please make sure that the travel range in your radio is same. Try to set 100% Gyro Gain and verify in the Diagnostic tab what value you can see there. You might just change travel little bit. |
Author: | blarks [ Sun 03. Mar 2019 13:31:38 ] |
ZeXx86 wrote: Hello, please make sure that the travel range in your radio is same. Try to set 100% Gyro Gain and verify in the Diagnostic tab what value you can see there. You might just change travel little bit. 100% in transmitter = 100% in diagnostic full green bar 50% in transmitter = 0% in diagnostic green bar in the middle 0% in transmitter = 100% in diagnostic no green bar 51% in transmitter =1% in diagnostic tab 52% in transmitter = 3% in diagnostic tab 53% in transmitter = 5% in diagnostic tab 54 % in transmitter = 7% in diagnostic tab and so on. so the endpoints are correct but the individual steps are not, 1 step in transmitter = 2 steps in diagnostic tab Does it have something to do with that there is only 0-100 in transmitter but there is effectively 200 in spirit? 0 to 100% and 0 to -100% |
Author: | blarks [ Tue 05. Mar 2019 5:45:39 ] |
blarks wrote: ZeXx86 wrote: Hello, please make sure that the travel range in your radio is same. Try to set 100% Gyro Gain and verify in the Diagnostic tab what value you can see there. You might just change travel little bit. 100% in transmitter = 100% in diagnostic full green bar 50% in transmitter = 0% in diagnostic green bar in the middle 0% in transmitter = 100% in diagnostic no green bar 51% in transmitter =1% in diagnostic tab 52% in transmitter = 3% in diagnostic tab 53% in transmitter = 5% in diagnostic tab 54 % in transmitter = 7% in diagnostic tab and so on. so the endpoints are correct but the individual steps are not, 1 step in transmitter = 2 steps in diagnostic tab Does it have something to do with that there is only 0-100 in transmitter but there is effectively 200 in spirit? 0 to 100% and 0 to -100% Is this correct for the horus x10s on frsky os? |
Author: | ZeXx86 [ Tue 05. Mar 2019 8:47:20 ] |
Hello, I am not sure but it should be possible to change the range of the channel. With OpenTX it correspond with -100 - 100% gain. In any way it is not a problem at all. You just have to know that 50% correspond to 0%, 0% to -100% and 100% to 100%. So flying Gyro Gain should be above 50%, probably between 60 - 80%. |
Author: | blarks [ Tue 05. Mar 2019 10:01:01 ] |
ZeXx86 wrote: Hello, I am not sure but it should be possible to change the range of the channel. With OpenTX it correspond with -100 - 100% gain. In any way it is not a problem at all. You just have to know that 50% correspond to 0%, 0% to -100% and 100% to 100%. So flying Gyro Gain should be above 50%, probably between 60 - 80%. Thank you ZeXx86, I didn't think it would be a problem, I will look into it further and see if I can change, but as you say it shouldn't be a problem, just need to remember that it is double the increments from the TX. At any rate have set it at 60 for now and will see how it flies. Will frsky os and spirit integration happen soon? |
Author: | ZeXx86 [ Wed 06. Mar 2019 10:25:13 ] |
Great. We hope that the integration will be available soon also for the Frsky OS. |
