how to config spirit for 4 degrees pitch in middle of stick https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=3183 |
Page 1 of 1 |
Author: | lottermann [ Sat 02. Mar 2019 14:45:45 ] |
Post subject: | how to config spirit for 4 degrees pitch in middle of stick |
Hi all, I want to configure my spirit for 4 degrees pitch in the middle of the stick, Pitch max. 10 degrees and pitch min. -2 degrees, because i do not fly 3D but Scale. At stick center then the servo arms are perpendicular to the linkages According to the instructions, 0 degrees and pitch max. and min. then set + -10 degrees What do I have to do to configure the system according to my ideas? Or is not that possible? An answer would be very nice Greetings Dirk |
Author: | urgno [ Sat 02. Mar 2019 19:51:18 ] |
Post subject: | Re: how to config spirit for 4 degrees pitch in middle of st |
you just need to use the pitch curve on your TX |
Author: | lottermann [ Sun 03. Mar 2019 20:58:34 ] |
Following problem: The Spirit requires 0 ° pitch at the middle of the stick. Conceivable and tried variants: Variant A: 1) normal setup with 0 ° in the middle of the stick 2) in the transmitter pitch curve so that it runs on the leaves from -2 ° down to 4 ° center and 10 ° above. BUT: clearly turned from the middle servos with little reserve for cyclic in the upper area. Variant B: Pitch at middle of signal mechanically to 4 °: Servo paths are ideal for this head-TS combination. Below a low negative pitch, enough up to 10 ° max. The geometry of the servo lever positions, the center levers in each case, fits with the 4 ° hover pitch in the center of the billet. BUT: The system is lied, it believes 0 ° at a true 4 °. What did your Scaleflighters do, on this point? I hope I have formulated my problem reasonably comprehensible. |
Author: | urgno [ Mon 04. Mar 2019 9:00:23 ] |
teach to spirit the 0° at middle of stick with all ciclic servos at 90° thats all then you can play your pitch curve how you want, you can even move the 0° pitch point away from middle stick |
Author: | Kluftinger [ Mon 04. Mar 2019 18:53:35 ] |
If you use the SOKO tool for the head adjustment you can have any pitch value at the "Zero Pitch" position you want. This tool is assembled to one blade holder and you turn the head and align the upper link with each servo link. Usually you adjust "0" pitch with each slider, but you can also adjust +4°. The upper reading of the SOKO tool reads always the true angle of the blade. Repeat the procedure with the second blade holder. |
Author: | ZeXx86 [ Mon 04. Mar 2019 22:27:02 ] |
It is important to have 0° pitch when the Diagnostic tab shows you 0% for the Pitch. Then you can set any pitch curve in your radio. |
Author: | lottermann [ Tue 05. Mar 2019 18:56:18 ] |
ZeXx86 wrote: It is important to have 0° pitch when the Diagnostic tab shows you 0% for the Pitch. Then you can set any pitch curve in your radio. Thanks for the Information,i do it on this way. Regards Dirk |
