It is currently Mon 25. Nov 2024 5:54:13
PostPosted: Sat 23. Feb 2019 20:25:38
Is it possible to have the following configuration with a standard red spirit?
Spirit Red with Spirit Governor
Geolink
HW v4 telemetry (for current measurement)
FrSky R-XSR via SBUS receiver
FrSky telemetry for Taranis integration and current consumption readout.
I'd like my taranis to give me a callout when i've used 1000mah, 1100mah, 1200mah etc, so need to use HW v4 current sensing and frsky s.port telem to pass the current usage to the taranis.
Using flight timers should be well in the past now.
PostPosted: Sun 24. Feb 2019 23:33:32
unfortunately this is not possible with Spirit unit. You can't connect GeoLink and HW telemetry cable at the same connector.
With Spirit Pro it is possible since it has two Spektrum connectors.
Users browsing this forum: Google [Bot] and 37 guests
