Wifi reading data -spirit unit not found https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=3161 |
Page 1 of 2 |
Author: | jjuk [ Fri 15. Feb 2019 19:37:46 ] |
Post subject: | Wifi reading data -spirit unit not found |
Both my wifi units are giving this error. Trying to connect from my android phone to a red spirit 2.6.1. Any ideas? BEC is 7.2v if that matters? PC USB dongle connection works perfectly. |
Author: | ZeXx86 [ Mon 18. Feb 2019 8:33:40 ] |
Post subject: | Re: Wifi reading data -spirit unit not found |
Hello, are you powering the Wifi-Link from the same power supply? (BEC from the model)? |
Author: | jjuk [ Tue 19. Feb 2019 22:39:54 ] |
Yes. I have unplugged the ESC (with bec), and plugged in a servo Y-cable. This then powers the WIFI module and the Spirit at the same time. The WIFI module is connected to my phone (my phone can connect to the spirit wifi), but cannot read data from the Spirit. |
Author: | urgno [ Wed 20. Feb 2019 1:29:26 ] |
are the spirit and wifi module at the firmware version ? |
Author: | jjuk [ Wed 20. Feb 2019 7:40:00 ] |
Spirit is at 2.6.1. I didn't think the wifi module was update able. How did I update the wifi firmware? |
Author: | TomasN [ Wed 20. Feb 2019 8:49:02 ] |
jjuk wrote: Spirit is at 2.6.1. See WiFi link section at http://www.spirit-system.com/download.php
Author: | jjuk [ Wed 20. Feb 2019 23:13:05 ] |
It was running v2.0.2 I've updated to 2.6.0 and will report back. Thanks! |
Author: | jjuk [ Thu 21. Feb 2019 13:41:12 ] |
One of the wifi modules is now working. The 2nd wifi module will not connect. I think I need to return it. |
Author: | ZeXx86 [ Fri 22. Feb 2019 9:02:42 ] |
Hello, did you updated also the second module? Can you see what version is in the module? The version between Wifi-Link and for Spirit unit must be always same. |
Author: | jjuk [ Fri 22. Feb 2019 11:11:24 ] |
Spirit is 6.2.1, wifi is 6.2.0. |
