It is currently Mon 25. Nov 2024 4:39:59
[ 5 posts ] |
stewartgrant37
Posted: Wed 06. Feb 2019 4:34:10 |
My Helicopter is a Trex 500X with a Spirit Pro and Geolink Module. I have set bank 0 to normal stabilisation, bank 1 to coaxial stabilisation and bank 2 to rescue normal. With bank 1 (coaxial) selected, when I change to bank 2 rescue normal (with mixing/momentary switch) it seems to behave normally. It changes from -6 pitch (with lowest collective stick position) to +6 pitch.
With bank 0 selected (stabilisation normal), when I change to bank 2 the pitch only changes from -12 to -6.
When connected to the Spirit software With bank 0 selected (stabilisation normal), when I change to bank 2 the pitch changes from -12 to +6. I have saved the settings to the unit's memory and everything else seems to be working normally. Not sure why it behaves as I would expect only when connected.
Thanks Grant
I must be missing something fundamental. I have reloaded the firmware and run through the setup again but still get the same result. Rescue (bank 2) only works from stabilisation normal (bank 0) when I am connected to the Spirit software with the diagnostic tab open. When disconnected, the collective pitch doesn't change when collective is at 0 degrees and from collective -12 degrees it moves to -6 degrees. Same result whether I connect with USB or Wifi. I would be grateful if anyone has any ideas. I am using firmware version 2.6.1.4 and software version 2.6.1. Thanks.
Posted: Fri 08. Feb 2019 13:28:50 |
the problem could occur if your settings has different Pitch Range between Banks.
Please check Backup/Bank Comparison to see if there is any difference in the basic settings. Unfortunately attached 4ds profile is only from single bank, so I can't check next. Each bank has own file.
stewartgrant37
Posted: Sat 09. Feb 2019 8:19:39 |
Thank you. I checked the pitch ranges and they were different in one bank. I corrected that and now the pitch angles make sense. I set the rescue collective pitch at 70% and when I switch to bank 2 (rescue) I get around +8 degrees from both bank 1 and bank 2. (Normal & coaxial). There is still an issue when the unit is disconnected from the configuration software. In normal-stabilsation mode (bnk0) the collective pitch doesn't change when I select rescue (bnk2). It does works correctly when I select rescue from coaxial mode (bnk1). When connected to the software the banks change correctly in the diagnostic tab and the collective pitch also changes correctly on the heli. I have checked the bank comparison and there is now no difference between the banks other than the stabi mode selected. I have attached the 3 files. Regards Grant
Posted: Sun 10. Feb 2019 23:00:26 |
thank you.
When you are checking the Banks is the software closed so that you are really turn it off? This mean close it before disconnecting the cable. The Status LED of the Spirit unit should be steady on, not to flash.
stewartgrant37
Posted: Mon 11. Feb 2019 8:54:00 |
Hi. Yes. I close the software before disconnecting the cable. The LED on the unit becomes steady once I disconnect.
Thanks Grant
[ 5 posts ] |
Users browsing this forum: No registered users and 74 guests |
