It is currently Mon 25. Nov 2024 4:55:40
 Post subject: No RX voltage
PostPosted: Sun 10. Feb 2019 7:49:09
I have the 4649T receiver and a talon 25 connected to an oxy3. I have an iX12 transmitter. I have gotten all the telemetry to work but I do not get RX voltage. I read that the 4649T doesnt send this value on its own. It either has to come from the ESC or the FBL controller. I dont think the Talon 25 send the BEC voltage as telemetry. Can the Spirit send this voltage somehow?
 Post subject: Re: No RX voltage
PostPosted: Sun 10. Feb 2019 22:35:00
you have to connect pin from the SPM4649T receiver at the BEC. This pin is sensing voltage - it is wired out in the second (normally unused) connector.
Talon is sending the value as far as we know. So actually it should be visible as the BEC [V] at the ESC status page. This mean that if the ESC is supporting this, the Spirit unit will send it.
PostPosted: Mon 11. Feb 2019 1:20:07
I am not sure the Talon 35 is sending the BEC voltage as telemetry data I sent a note to castle creation to find out. I believe the voltage sense port is for main pack voltage correct? If I use that to sense BEC voltage I think it will override the Talon ESC main voltage data.
PostPosted: Mon 11. Feb 2019 8:12:06
The SPM4649T port has uncoupled telemetry with ESC. So you can use the measurement port for anything you like - BEC or main battery voltage or just one cell.
Users browsing this forum: Bing [Bot] and 74 guests
