It is currently Sun 24. Nov 2024 18:00:45
[ 5 posts ] |
Franky13
Posted: Thu 31. Jan 2019 15:38:48 |
Hello! How do I connect the new YGE 205 HVT with BEC to the SpiritPro? The YGE protocol is also intended for the Spirtit FBL-System! Jeti EX Bus is possible.
My equipment: REX3, SpiritPro and YGE 205HVT with BEC
Photo attached. Thank you! Greeting Frank
Attachments: |
Franky13
Posted: Fri 01. Feb 2019 22:04:00 |
Nobody a suggestion. Or maybe tomas?
Posted: Fri 01. Feb 2019 22:16:42 |
If possible, combine BEC cable and Throttle signal into one cable - primary. Second cable will be just for BEC - secondary. This will allow having just two cables instead of 3.
Then connect primary cable at the AUX1 and secondary at the AUX2 port and all will be fine.
Telemetry can be connected in a way you wish - to JETI receiver or Spirit unit.
Franky13
Posted: Sun 03. Feb 2019 11:19:12 |
Ok, thanks!
I then put the receiver signal cable in the BEC cable. The minus cable (from the receiver) too, or "disconnect"? Then the new BEC cable in AUX1!
Greeting
Posted: Mon 04. Feb 2019 8:27:30 |
It should be enough to use GND (-) from BEC connector. So Receiver GND will be unused.
[ 5 posts ] |
Users browsing this forum: Flapflap and 84 guests |
