It is currently Sun 24. Nov 2024 17:26:12
PostPosted: Sun 03. Feb 2019 19:45:12
hi guys,
I have been out of helicopters for a while and I am almost forgot everything.
Basically, I never had any problem with my old setting. Yesterday I ve decided to update both firmware and software to the latest version.
Everything seems ok except the rescue which doesn't work anymore.
Waht could be changed?
In the servos screen gyro says head lock 45%. I am not using banks.
Hope someone could help me.
Thank you!
PostPosted: Sun 03. Feb 2019 21:14:55
If you are using Special Function to activate Rescue then check your Channel Mapping in the software. If you went to 2.6.0 or 2.6.1 from an earlier version these Functions got reset. This was do allowing the usage of additional channels.
PostPosted: Mon 04. Feb 2019 7:22:35
Thank you so much.
I will try to figure out how to let it work again than..
Cheers
PostPosted: Mon 04. Feb 2019 8:11:42
It is enough to reload your settings or just set up the Special Functions in the Channels window. For example Channel 8 to F: Stabi Function.
PostPosted: Mon 04. Feb 2019 20:49:39
thank you so much, now it works! is this enough or is there anything else I need to change? I only assigned stabi function to channel 8.
Users browsing this forum: No registered users and 67 guests
