[SOLVED] SpiritPro doesn't react on RX signals https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=3125 |
Page 1 of 1 |
Author: | scvflyer [ Thu 31. Jan 2019 21:28:22 ] |
Post subject: | [SOLVED] SpiritPro doesn't react on RX signals |
Hello serviceteam, after a crash - I rebuild the system and did an software update for SpiritPro to 2.6.1. But no channel signal from TX/RX recognized at SpiritPro - no physical reaction nor at diagnose screens at spirit software. Current status: * TX and Receiver has been changed to be sure that this part is fine - SUMD (test with Graupner) and SBUS (test with FrSky) * Init phase seems to be okay - TS and Servos will be centered properly - but red light flashs * BEC Test works well * Adjusting Servo to get TS zero position - works well * Reset to factory setting has no effect Any idea thanks and br siggi |
Author: | ZeXx86 [ Thu 31. Jan 2019 22:02:20 ] |
Post subject: | Re: SpiritPro doesn't react on RX signals |
Hello, please make sure that the correct Receiver type is configured in the Spirit Settings and that it will persist after re-power. I guess that the problem is just there. |
Author: | scvflyer [ Thu 31. Jan 2019 22:35:53 ] |
Hello, you are right - re-power is the magic thing thanks and br siggi |
