It is currently Mon 25. Nov 2024 1:36:29
PostPosted: Sun 30. Dec 2018 12:55:12
I have a channel assigned to the stabi function and another to the gyro gain, but rescue doesn’t work if the gyro gain channel isn’t negative.
Rescue should work when the assigned stabi channel is on regardless of gyro channel setting or gyro mode.
Than You for your Help
PostPosted: Sun 30. Dec 2018 13:23:22
This is done by intention and works as designed, you can check in the manual. However, I needed to mess around with my transmitter to get it to work properly because negative gains are not supported on all transmitters out of the box.
BR Eugen
Users browsing this forum: No registered users and 42 guests
