It is currently Mon 25. Nov 2024 2:28:29
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri 02. Nov 2018 13:39:03
Where do I plug in my second spektrum satellite when I'm using geolink with the Spirit pro?
PostPosted: Fri 02. Nov 2018 13:54:18
You gonna have to buy the spektrum satelite adapter or spektrum multi adapter from the spirit E-shop and the manual/product page will tell you where to plug it in on the spirit pro.
You can use up to 3 sats on the pro if you are using geolink.
Hope this helps.
Sent from my SM-N950W using Tapatalk
PostPosted: Fri 02. Nov 2018 15:29:29
Rufus wrote:
You gonna have to buy the spektrum satelite adapter or spektrum multi adapter from the spirit E-shop and the manul/product page will tell you where to plug it in on the spirit pro.
Hope this helps.
So this:
http://store.spirit-system.com/en/acces ... multi.html
or this:
http://store.spirit-system.com/en/acces ... er-v2.html
right?
I can't just change my jst plug on the satalite to a servo plug and then put it into the aux port?
PostPosted: Fri 02. Nov 2018 16:58:26
no, the satellite works at 3,3V while on AUX (and the other connectors) you have the direct BEC voltage
5V or higher, depends on your BEC
the adapter contains the right hardware to lower the voltage to 3.3V
PostPosted: Fri 02. Nov 2018 22:14:25
Thanks..
PostPosted: Tue 20. Nov 2018 10:23:01
So I got the cable, but can’t get it working using the rud port.
The satellites don’t even light up when they are connected to the adapter cable. Should I set something up in the software or what?
Is it possible to use the adapter cable for the geolink instead? I tried that as well, but it doesn’t see nor power up the geolink..
PostPosted: Tue 20. Nov 2018 11:48:11
have you connected it correctly ?
http://manual.spirit-system.com/index.p ... ti_Adapter
PostPosted: Tue 20. Nov 2018 12:01:23
I don’t have the multi adapter, just the single 1 sat adapter..
It does say though: Before usage please bind satellites that are intended to be connected to the adapter through primary and secondary ports.
Does this mean that I must connect my two satalites to the side ports when I bind, and then use the adapter in the rud port afterwards?
But what if I want to use 3 satalittes?
What port is the primary port?
PostPosted: Tue 20. Nov 2018 15:38:12
YES
then you need the multi adapter
>> Cable for connecting up to 3 Spektrum satellites with Spirit and up to 4 satellites with Spirit Pro unit.
of course if you use the geo-link, you subtract 1 from these numbers
if you read throughly the manual, the info are all available :)
here you can see the geolink connected to secondary port of spirit pro
(the only unit that actually have primary and secondary satellite port)
the other port is the primary ;)
here another pic that is very clear ( from the wiki manual )
PostPosted: Tue 20. Nov 2018 16:51:50
Many thanks, I’ll try it in a couple of weeks. I just realized that one of my satalites seems to have broken although it bonds correctly and everything. When I remove my working satalites I can only control my elevator servo.
I also have a TM1000 telemetry unit that I will be using. Does anyone know if this can communicate with the spirit system in terms of data logging? As of right now I’m just powering it through my aux port.
Would be cool if I could use my rpm sensor as a gov as well...
Kind Regards,
Peter
Users browsing this forum: No registered users and 50 guests
