Spirit for rotor cycle diameter 1500mm or spirit pro? https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2989 |
Page 1 of 1 |
Author: | lottermann [ Tue 20. Nov 2018 16:57:59 ] |
Post subject: | Spirit for rotor cycle diameter 1500mm or spirit pro? |
I bought the spirit for a t-rex 470 some time ago. Can I use the spirit as a stabilizer and gyroscope for a helicopter with paddles and rotor cycle diameter 1500mm or do I need the spirit pro? regards Dirk |
Author: | urgno [ Tue 20. Nov 2018 17:25:24 ] |
Post subject: | Re: Spirit for rotor cycle diameter 1500mm or spirit pro? |
spirit (non pro) is suggested till 500-550 |
Author: | ZeXx86 [ Wed 21. Nov 2018 15:39:56 ] |
Hello, it will work well, but we recommend to use Spirit Pro because of more available ports - especially for powering. So you might need Y-cable to power the unit at least with two BEC cables. But this also depends on receiver you would like to use. |
