Kontronik Helijive Telemetry https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2986 |
Page 1 of 1 |
Author: | omegatron [ Mon 19. Nov 2018 2:00:58 ] |
Post subject: | Kontronik Helijive Telemetry |
Does Spirit support telemetry for Kontronik Helijive? I don't see it listed in the ESC section, but I'm also unsure if it uses the same protocol as the Jive series esc which are supported. Thanks, |
Author: | augur [ Mon 19. Nov 2018 6:50:12 ] |
Post subject: | Re: Kontronik Helijive Telemetry |
Hi. Helijive has the same protocol than the old ones. Nils |
Author: | Planehazza [ Sun 07. Jun 2020 18:22:08 ] |
augur wrote: Hi. Helijive has the same protocol than the old ones. Nils Is that a yes or a no? |
Author: | augur [ Sun 07. Jun 2020 21:50:00 ] |
A yes. But not all available values are transmitted via Spirit in general. If you like PWM and some other details you need a Jlog. I already asked to enhance it but actually switched to Jlog as I like PWM to get the right pinion. |
Author: | Planehazza [ Sun 07. Jun 2020 22:11:23 ] |
augur wrote: A yes. But not all available values are transmitted via Spirit in general. If you like PWM and some other details you need a Jlog. I already asked to enhance it but actually switched to Jlog as I like PWM to get the right pinion. Thanks. I have a powerjive 120+HV and I’m hoping to connect it to my Spirit for rpm and battery capacity. |
