It is currently Sun 24. Nov 2024 13:34:38
 Post subject: Acro rescue channel
PostPosted: Tue 20. Nov 2018 10:26:26
Is it just me or is it not possible to assign Acro rescue to a channel?
I want to assign both altitude hold and geofence to stabi so I can activate both with one button, but then it seems that I will then not be able to use rescue..
 Post subject: Re: Acro rescue channel
PostPosted: Wed 21. Nov 2018 15:57:21
You can use F: Stabi Function to engage the Rescue or other mode with a dedicated channel.
See this guide:
http://manual.spirit-system.com/index.p ... te_channel
GeoLink features can be engaged also with (other) assigned channels independently. You can assign same channel for GeoLink features.
So one channel will engage the Rescue while other will engage a GeoLink features.
PostPosted: Thu 22. Nov 2018 9:39:34
Hi
Thanks for the response, and yes I’m aware of that..
What I’m asking is:
Is there a way to activate geo-fence and altitude limit on the same time on a single channel, and then having Acro rescue on another separate channel?
Or asked in another way: is it possible to active Acro rescue without stabi function, and then only assign geo-fence and altitude limit to stabi.
Br, Peter
PostPosted: Fri 23. Nov 2018 8:41:04
Yes, it can be done in the way I described.
I just dont understand what do you mean by "without stabi function".
If you want that Geo-fence and Altitude Limit are engaged by Stabi function then it will be always triggered as soon as you will engage Rescue/Stabilisation/Coaxial mode (by any way).
So these both should be assigned with F: Geo-Link Geo-fence and F: Geo-Link Altitude Limit to a same channel. Rescue can be engaged by a different channel.
Users browsing this forum: mainstreet and 33 guests
