It is currently Mon 25. Nov 2024 0:54:46
[ 3 posts ] |
carl0s
Posted: Tue 13. Nov 2018 0:40:06 |
Hi.
I am confused for how to make a momentary switch activate Rescue mode, while still having Stabi->Stabilisation enabled all the time in the bank.
Do I need to make my momentary button switch banks?
It doesn't make sense for the Channel assignment. This says I can assign a channel to 'Stabi Function' but where do I choose which Stabi function this channel/button will enable?
and in the Stabi-> Function tab, it says 'function activated when gyro gain is negative'.
OK I think I get it now. Either negative gyro gain, or switch function, will activate whatever is set in stabi tab.
If I want the flight modes to switch 3 banks, as well as have a 2-position momentary switch that enabled just rescue, I suppose I need to mix the momentary switch to the flight-mode switch on the TX?
carl0s
Posted: Tue 13. Nov 2018 1:08:17 |
I am struggling with this a bit.
it looks like I have to use bank switching.
but I can't see how to use an on/off switch to switch between banks 0/1, and have a 3-pos switch to select the banks as well.
basically I want the momentary for rescue (bank 2), but also to be able to use another switch for banks 0 and 1.
only option I can see is to limit the end-point of one of the switched to half way ?
carl0s
Posted: Tue 13. Nov 2018 4:00:20 |
It's OK I managed it with the mixer on the TX. Thought it might be easier than that but it's all good.
[ 3 posts ] |
Users browsing this forum: No registered users and 71 guests |
