Spirit System
Throttle Servo Connection
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2963
Page 1 of 2
Author:  Jimbob [ Sat 10. Nov 2018 16:56:30 ]
Post subject:  Throttle Servo Connection
Hi All.
Just setting up my first flybarless and I have a Spirit on a TRex 600n DFC
I have everything working OK, but I cannot seem to find in the manual (or anywhere) much info regarding the nitro throttle and governor setup.
I cannot even get the throttle servo working from the Spirit.
Where does the throttle servo connect to?
Cheers,
Jim
My setup is:
Futaba T16SZ,
Futaba R2008SB HV over S-Bus
Spirit controller
Futaba S3470SV for throttle
Spartan Governor Sensor.
Author:  ZeXx86 [ Sat 10. Nov 2018 17:00:31 ]
Post subject:  Re: Throttle Servo Connection
you can find the details in our manual and also Spirit Settings.
Please check this page:
http://manual.spirit-system.com/index.p ... TOR_WIRING
Author:  Jimbob [ Sat 10. Nov 2018 17:09:38 ]
Hi, and thanks for the reply.
I have tried connecting the servo to the AUX connector as per the description in your link, and I have also assigned throttle to channel 1 in the rx settings page.
The throttle servo just doesnt move - it doesnt even seem to have any power from the AUX port.
If I plug it directly into the RX it moves OK, but I want to use the governor function.
Is there anything else I should look at?
Jim.
Author:  ZeXx86 [ Sat 10. Nov 2018 17:16:57 ]
Is your receiver connection working with Spirit unit? You can check it in the Diagnostic tab. You will see a movement of the channels.
If your radio is off then the servo will behave as a dead.
Other explanation could be that the servo is connected in the opposite way.
It should also move when you connect it to any other position such as CH1,2,3,4.
Author:  Jimbob [ Sat 10. Nov 2018 17:23:21 ]
Hi.
When I move the Tx throttle I see the throttle bar moving on the diagnostics screen.
If I connect the throttle servo to say CH1, then it will move with the cyclic.
If I connect it directly to the Rx then it moves ok.
It seems that the AUX output is not working or some reason.
Jim
Author:  Jimbob [ Sat 10. Nov 2018 17:39:39 ]
I just checked and there is about +8v between the power pins of the AUX connector.
Author:  ZeXx86 [ Sat 10. Nov 2018 17:53:36 ]
Very well.
Please make sure that the Throttle channel is really assigned in the General/Channels window.
If changing Receiver type it will unassign.
Author:  Jimbob [ Sun 11. Nov 2018 20:57:04 ]
ZeXx86 wrote:
Very well.
Hi
So I checked that the Throttle channel is set to 1, and it says it is.
I tried changeing it to another channel and then back again - no change,
I have now put a S148 servo on the aux connector - on power up, the Spirit drives the servo completely CCW where is stays, buzzing.
Nothing I can do changes this.
The other S3470SV servo still works fine directly connected to the Rx but is totally dead on the Spirit AUX connector.
Very strange - any more ideas for me?
Cheers,
Jim
Author:  urgno [ Mon 12. Nov 2018 11:11:19 ]
maybe the throttle frequency/pulse is not the right one for the servo you connected ?
NOTE1 the spirit throttle actually support 1520μs servos
NOTE2 the S148 just support 4.8V - 6.0V ... you wrote you have 8V so be careful
NOTE3 the S3470SV is SBUS2 servo, are you sure it will work with pwm signal ?
Author:  Jimbob [ Mon 12. Nov 2018 12:48:32 ]
NOTE1 the spirit throttle actually support 1520μs servos [/quote]
I will look into the freq/pulse as a possible point of issue. What throttle servos are people using generally?
Yes thanks. I have used a 6v NiMh when testing with the S148.
I knew it was SBUS2, but it works fine direct from a PWM port on the Rx, so I was thinking that proved its suitability. Is this not the case perhaps?
Thanks very much for your input,
Jim
http://www.phpbb.com/
