peter- wrote:
I don’t have the multi adapter, just the single 1 sat adapter..
It does say though: Before usage please bind satellites that are intended to be connected to the adapter through primary and secondary ports.
Does this mean that I must connect my two satalites to the side ports when I bind, and then use the adapter in the rud port afterwards?
YES
peter- wrote:
But what if I want to use 3 satalittes?
then you need the multi adapter
>> Cable for connecting up to 3 Spektrum satellites with Spirit and up to 4 satellites with Spirit Pro unit.
of course if you use the geo-link, you subtract 1 from these numbers
peter- wrote:
What port is the primary port?
if you read throughly the manual, the info are all available
here you can see the geolink connected to secondary port of spirit pro
(the only unit that actually have primary and secondary satellite port)
the other port is the primary
here another pic that is very clear ( from the wiki manual )
