It is currently Mon 25. Nov 2024 2:43:21
 Post subject: [SOLVED] Governor sensor
PostPosted: Sun 07. Oct 2018 12:23:58
Hi there,
I could not fly today due to governor sensor failure,I've been using Align gov sensor for Spirit fbl governor for a while,
I think it's a hall sensor since it works with magnets.
Here is my question comes, I need sensor immediately, if I try to use a simple hall sensor like US1881 Hall Effect Sensor, does it work?
 Post subject: Re: Governor sensor
PostPosted: Thu 11. Oct 2018 20:53:12
I've bought super cheap US1881 hall effect sensor from a local electronic store,
Soldered according to it's datasheet, powered from receiver directly due to min 4.5vdc power requirement,
So far so good, it works better than original,
I have more stable rpm readouts now,
ciao
PostPosted: Fri 12. Oct 2018 7:57:25
thank you for your message. You are good engineer :)
Users browsing this forum: Bing [Bot] and 96 guests
