It is currently Mon 25. Nov 2024 1:44:59
PostPosted: Thu 20. Sep 2018 13:23:43
which vibration values with HoTT telemetry are very good, good, ok, bad...? Is there a chart for that?
Altitude value is pending between 3 and 5
(Fuel value always 100ml ?)
Thank you
PostPosted: Fri 28. Sep 2018 10:46:20
Hello Pusher,
I had a similar question to vibrations in Hott Telemetry.
This is the link to the post.
Maybe it could help You.
viewtopic.php?f=20&t=2512&hilit=hott+telemetry
With best regards
Roland
PostPosted: Wed 03. Oct 2018 8:08:27
if the value is under 10 in the most cases the model is fine.
But for precise measurement we recommend to use Spectrum Analyzer. Usually Y axis is the worst.
Users browsing this forum: No registered users and 46 guests
