It is currently Mon 25. Nov 2024 2:50:18
PostPosted: Fri 12. Oct 2018 18:30:34
I have a Spirit Pro in a Goblin 380 running KST servos. I had a blade strike and had to change a servo and other parts. Now when I Initialize the Spirit the servos move differently than before. I also programmed in 2 banks after the blade strike. One for normal flight and one with stabilization and rescue to work with both. If I am in the normal flight bank the servos go to level then the aileron servo goes down once then back to level. When I initialize in the stabilization mode the the servos go to level then the Aileron servo goes up and down 3 times then to level. I have check the condition with other servos and it still occurs. Any help would be appreciated.
Tom
PostPosted: Fri 12. Oct 2018 21:33:19
This mean that the Spirit unit has log saved in the memory as described in the manual.
You have to just check the flight log and then the behavior will be normal.
PostPosted: Sat 13. Oct 2018 2:36:41
PostPosted: Sat 13. Oct 2018 8:13:46
You are welcome.
Users browsing this forum: Bing [Bot] and 85 guests
