It is currently Sun 24. Nov 2024 22:18:53
PostPosted: Fri 07. Sep 2018 23:30:10
Good day guys...
I'm at wits end trying to do this and I think it might not be possible.
This is what I'm trying to do...
Logo 480xx
Regular spirit fbl
Yge 90LV(using internal BEC)
Ultraguard backup
Geolink
I know the regular spirit is limited in ports so how will I go about wiring all this together or are there specific cables that will help me achieve this ? There are 8 ports,ESC has taken 2,servos 4 and I'm left with system and ele/pit ports which can't be used for any of the things I would like to use.
And now I would like to use geolink,so that means I've lost the sat port and will need an adapter to use the sat...but I've run out of ports....sigh.
Guys,please help and advise before I lose what's left of my balding hair...
Sent from my SM-N950W using Tapatalk
PostPosted: Sat 08. Sep 2018 3:52:58
Wrong thread :roll:
PostPosted: Sat 08. Sep 2018 10:43:11
Hello Rufus,
I recommend to get at least 1x Y-cable and 1x Spektrum Multi Adapter that we offer.
Then you can connect:
Y-cable at the AUX port where you can feed primary and secondary cable from the ESC. Alternatively only primary cable will be used since your model has not that high demands but it is better to use both.
Spektrum Multi Adapter will be then used for 2 satellites. In that way you can connect GeoLink and use 2 Spektrum satellites without any problem.
PostPosted: Sat 08. Sep 2018 15:03:28
Beautiful...this covers Geolink and the sats.
To use my backup guard,can I use another Y-cable and share a servo and its port with the backup guard ? There will be no problems ?
Much apprecuated Tomas.
ZeXx86 wrote:
Hello Rufus,
PostPosted: Sat 08. Sep 2018 20:34:19
Yes, you can use next Y-cable for example at CH4.
PostPosted: Sat 08. Sep 2018 23:05:07
Much appreciated...Everything works perfect and smooth...
Users browsing this forum: No registered users and 30 guests
