It is currently Sun 24. Nov 2024 20:35:28
Post new topic Reply to topic  [ 14 posts ]  Go to page 1, 2  Next
 Post subject: Spektrum analyzer
PostPosted: Sun 09. Sep 2018 22:00:10
brand new Spirit pro , and I'm not getting any readings on the vibration analyzer , even stimulated vibration by putting a bolt on one of the tailblade holder and had insane vibrations on the table but no readings on the analyzer , wondering if its a bad unit
https://www.youtube.com/watch?v=ihMsZJLofQ0
 Post subject: Re: Spektrum analyzer
PostPosted: Mon 10. Sep 2018 7:29:48
could you please verify what is the last digit of your serial number in the Connection tab?
This could reveal where the problem is. Did you performed some updates of the unit?
PostPosted: Mon 10. Sep 2018 8:58:16
yes the unit is updated to the latest firmware , will check the serial nr when I come home after work
PostPosted: Mon 10. Sep 2018 14:14:04
last digit is 10
version : 2.5.1
PostPosted: Mon 10. Sep 2018 14:16:06
This is interesting (and correct actually) - is this from the Connection tab, right?
But is the unit responding to a movement normally?
PostPosted: Mon 10. Sep 2018 14:22:49
yes it responding to stick movements , just sent pm with the whole serial nr.
PostPosted: Mon 10. Sep 2018 14:24:29
But is it also responding to model movement? Swashplate should move immediately after initialization if you will move with the model.
PostPosted: Mon 10. Sep 2018 14:44:25
https://www.youtube.com/watch?v=ePGxyGc ... e=youtu.be
PostPosted: Mon 10. Sep 2018 21:52:15
thinking of having the unit replaced
PostPosted: Mon 10. Sep 2018 21:57:14
Thank you for the video.
From the video I can see that the Spektrum analyzer is not working as you described.
But is the model reacting when you are moving with the model? (Not with sticks)
You should see that the swashplate and gyro is reacting from the beginning. Was it not reacting from the beginning?
Users browsing this forum: Bing [Bot] and 70 guests
