Spirit System
Geolink Cable sensitivity to magnetic field !
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2812
Author:  Van Scott [ Sat 08. Sep 2018 0:53:44 ]
Post subject:  Geolink Cable sensitivity to magnetic field !
I know the GeoLink needs to be away from magnetic fields to allow it to function correcty .
How about the connecting Cable , is it influenced in the same way or more robust ?
What would the closest the Cable could be safely run past something like a Motor or Servo ?
Author:  ZeXx86 [ Sat 08. Sep 2018 20:37:53 ]
Post subject:  Re: Geolink Cable sensitivity to magnetic field !
The cable can be much closer to the motor/servos.
3 cm distance or more should be fine.
Motor and ESC could induce a noise in these cables same as it will happen for BEC cables. But GeoLink has built-in voltage filters so it should be fine.
http://www.phpbb.com/
