It is currently Sun 24. Nov 2024 20:50:42
PostPosted: Sat 25. Aug 2018 4:08:14
I am connecting the SPM4649T along with the Hobbywing 80a v4 to a regular Spirit Red.
I know where the 2 signal wires go but my question is that both the Esc and the SPM4649T go to the Rud port. Can I use the y cable for these two cables?
Thanks!
 Post subject: Re: Rud port y cable
PostPosted: Sat 25. Aug 2018 8:38:11
the ESC cable should be connected at the AUX port, while SPM4649T at the RUD port/AIL ail.
If you want to connect secondary BEC cable, then yes, you can use Y cable and connect it at the RUD port there. There will be no issue with it.
PostPosted: Sat 25. Aug 2018 12:53:28
Users browsing this forum: No registered users and 70 guests
