It is currently Sun 24. Nov 2024 20:48:52
Page 1 of 1
[ 3 posts ] |
Author |
Message |
keeny
Posted: Sun 19. Aug 2018 12:38:34 |
Hi, Aileron in diagnostics shows the wrong direction to my transmitter however everything works as normal on the bench. Will this be an issue during flight. I had to reverse a servo or 2 get everything working in the first place. and the servos are connected in the right place on the unit. I am using Futaba s bus. Quick edit how come everything works on the bench yet the spirit unit thinks ailerons direction is going in the opposite direction?
Cheers, Chris.
Top |
Posted: Sun 19. Aug 2018 15:43:31 |
Site Admin |
it is necessary that you will see correct directions in the Diagnostic tab. This must always be correct otherwise it will not work well. So first you have to reverse aileron and then to reverse servos in the Servos tab.
You can also check Swashplate type and Position of the unit and servo wiring as these might influence on why one can't find a proper configuration.
Top |
keeny
Posted: Wed 22. Aug 2018 18:32:48 |
Thanks for your reply I went through it from scratch all is working as should now.
Cheers, Chris.
Top |
Page 1 of 1
[ 3 posts ] |
Who is online |
Users browsing this forum: No registered users and 68 guests |
