It is currently Sun 24. Nov 2024 20:34:03
Page 1 of 1
[ 3 posts ] |
Author |
Message |
grobjo
Posted: Sat 18. Aug 2018 12:22:08 |
What will happen if somebody is performing an autorotation with active altitude limit ? Is it possible that the system recognizes that the engine is off and disable the altitude limit funktion ?
Top |
TimD
Posted: Tue 21. Aug 2018 7:24:17 |
As far as I can tell the altitude limit will trigger the rescue function with obvious consiquenses. As a precaution I've programmed a simple mix to disable altitude limit and geofence when I hit throttle hold.
Top |
rediary
Posted: Tue 21. Aug 2018 15:25:58 |
Tim,
Did you happen to program that mix in a Spektrum transmitter (or know how to)? I've been cognizant of turning all safety features off manually before i bring it down for a landing but mixing this into the TH switch will be ideal. I've never had a need to use the mixing functions until now and don't really know how to set up the offsets correctly. Could you share your setup?
Top |
Page 1 of 1
[ 3 posts ] |
Who is online |
Users browsing this forum: Bing [Bot] and 59 guests |
