It is currently Sun 24. Nov 2024 20:53:44
PostPosted: Wed 15. Aug 2018 13:22:55
Hi, I was about to move my Spirit pro unit from one of my helis onto my Goblin 380.
The seperate aluminium mount will have to be used, as the pro unit is too wide for the main plate when using the belt tensioner pulleys, as the mounting bolts get in the way.
But the potential problem is that the aluminium mount is only 24.5 mm wide, which leaves a small overhang of the Spirit pro unit either side.
I suspect this will not be a problem but wanted to check first.
Thanks,
Eric.
PostPosted: Wed 15. Aug 2018 13:25:29
I also think it will not cause any problem. You can just use provided double sided tape and it should hold it firmly.
PostPosted: Wed 15. Aug 2018 17:40:52
Great thanks, Eric.
Users browsing this forum: No registered users and 65 guests
