It is currently Sun 24. Nov 2024 20:44:24
 Post subject: GeoLink & Stabi Function
PostPosted: Tue 07. Aug 2018 17:26:48
if I understand the manual correctly, chosen functions as for example Geo-Fence and Altitude Limit are active as soon as Stabi function is actived. Additionally I can assign up to 3 other functions to dedicated channels and switch them by dedicated switches on the radio.
In my earlier configuration Stabi-mode was activated by bank-switching. If I now switch banks in the software (because while connected to the software I can not switch banks on the radio), I can not check if the chosen functions are active in the GeoLink because the General tab is grayed out and I have no access to the Geolink.
Is there any way I can check if the wanted config is working other than in the field?
Best regards,
Alexander
PostPosted: Wed 08. Aug 2018 10:02:12
If you can see the functions are working in the GeoLink window, they will work always regardless bank switching.
But all features can be checked also on the bench from swashplate behavior.
PostPosted: Wed 08. Aug 2018 10:43:02
OK, but I can not see the Geolink window, when I switch bank to 1 or 2 to activate stabi function...
Best regards,
Alexander
PostPosted: Wed 08. Aug 2018 10:46:43
That is not a problem, it will be same for all banks.
PostPosted: Wed 08. Aug 2018 10:49:58
But in banks 1 and 2 the general tab is grayed out, so I can not access the Geolink window
PostPosted: Wed 08. Aug 2018 10:52:29
Yes, that is correct. You can access it in Bank 0 - this is because the settings are shared for all banks. It is same as for any other basic parameters such as mounting position or swashplate type. Settings are same for each bank.
PostPosted: Wed 08. Aug 2018 10:56:12
OK, but how can I check Geolink-settings, if I switch stabi function via bankswitching?
Users browsing this forum: Bing [Bot] and 60 guests
