Spirit System
goblin 700 t line rudder extents
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2671
Author:  Karl1081 [ Sat 28. Jul 2018 15:30:06 ]
Post subject:  goblin 700 t line rudder extents
just received my spirit pro and installed it into my goblin 700 t line , im having trouble with the rudder
i chose the goblin 700 pre set in wizard
i set my end points for rudder to max no problem ,but when i exit set up and use rudder on my tx the rudder is not travelling to its endpoints by quite abit . any suggestions .
also is there a walktrough on setting up rescue on a seperate switch on my dx9 , most of the ones ive seen have been using banks etc .
all i want to do is have rescue on a seperate switch .
many thanks for any help
Author:  ZeXx86 [ Sat 28. Jul 2018 22:24:10 ]
Post subject:  Re: goblin 700 t line rudder extents
probably your Gyro Gain is not configured and is left at 0% in your radio.
In this case Rudder mode is Normal (Rate) which is what you will don't like since tail will not hold too well.
You only have to set your Gyro Gain to something like 50% as recommended in the Setup Wizard and manual.
Once you will make your base configuration we can continue with Rescue.
Author:  Karl1081 [ Sun 29. Jul 2018 3:25:18 ]
Ok thanks. but I'm sure that's what I have all ready but will check for sure
Author:  Karl1081 [ Sun 29. Jul 2018 15:05:56 ]
Think it's sorted .Not sure what the reason was as rudder is now reaching extents. .
Id like to assign switch f on my dx9 to rescue as i pinch the tx sricks and wouldnt reach to rear of tx .is it poss to give me a walkthrough on how to acheive this .ive read so many different threads I'm confused
Regards karl
Author:  ZeXx86 [ Sun 29. Jul 2018 15:28:06 ]
that is great!
The easiest way in your transmitter could be to:
1. Assign a switch to Governor function in your radio. Governor because this function is usually unused and it can be freely used for anything. We need just to change channel value from -100% to 100%. This should be assigned to channel 7, 8, 9 or 10 - any that is unused.
I expect that you are using Spektrum satellite or other single-line receiver, right?
In the Channel Monitor you should be able to see that channel is really doing something when switching.
2. In the Spirit Settings, go to: General/Channels and assign F: Stabi function to Channel 7, 8, 9 or 10 (one that you selected in your radio).
3. Then in Stabi/Function set Rescue (Normal) or (Acro) and all is done.
When changing switch position the swashplate should move to the positive collective pitch. At this moment you are ready to fly.
Author:  Karl1081 [ Mon 30. Jul 2018 8:50:10 ]
ZeXx86 wrote:
that is great!
That's terrific and thanks . but I was under the assumption that the gain had to be switched to negative value to initiate rescue. How does the method above incorporate the gain if at all
Author:  ZeXx86 [ Tue 31. Jul 2018 8:07:34 ]
You are welcome :)
This method does not require any Gain changes. It is method described here:
http://manual.spirit-system.com/index.p ... te_channel
http://www.phpbb.com/
