It is currently Sun 24. Nov 2024 21:07:19
 Post subject: Spektrum Capacity Alarm
PostPosted: Sun 08. Apr 2018 10:04:30
Can the Spirit on the Spektrum Receiver 4669t and a Hobbywing regulator the battery consumption synonymous in Mha show and can be set as an alarm
PostPosted: Sun 08. Apr 2018 10:15:22
Yes, it can be configured with our unofficial firmware. I can send link for it. It is nearly same as 2.4.3 but has some improvements in the Spektrum integration and telemetry.
PostPosted: Sun 08. Apr 2018 10:48:55
Thanks for the super fast answer yes that would be great if you could send me the file
PostPosted: Sun 08. Apr 2018 11:04:07
You are welcome.
Here is the link:
http://spirit-system.com/dl/fw/spirit-fw-2.4.6.4df
You will just need to add the Capacity telemetry menu. There the consumed capacity will be displayed.
PostPosted: Mon 09. Apr 2018 5:32:23
Hello now have the software you've sent me successfully and it works synonymous with the battery consumption in telemetry. What I unfortunately can not but is the Spektrum IX12 the Flybarless on the station set there is something to note or must be an update on the spectrum
PostPosted: Wed 02. May 2018 9:29:40
I tried the FW 2.4.6. with my DX9 and the battery consumption works fine with allert and status voice report. But the RPM reading is wrong, it shows me a value of 20 or 30 in the esc status window. ESC is a jive pro 120 FW1.13. Number of poles and gear ratio are set in with the kontronik progunit. What can i do to get correct RPM reading ?
PostPosted: Wed 02. May 2018 19:29:22
You should set default settings for Gear Ratio/Motor Poles in your Konronik.
And also very important is to not configure this in your radio. You have to configure Gear Ratio and Sensing Divider only in the unit.
PostPosted: Wed 02. May 2018 21:55:21
Thomas,
Can you list what is improved about the Spektrum Telemetry in this firmware? I was waiting for a few enhancements and I would like to know if they are covered.
I am currently using 2.4.4
thanks!
PostPosted: Thu 03. May 2018 9:38:38
It is unofficial firmware that adds just support for Capacity displaying in the Capacity telemetry menu. This allows enabling alarm for consumed capacity in your radio.
PostPosted: Thu 03. May 2018 13:27:19
Oh. I'm already getting that in 2.4.4 with the Flight Pack Telemetry option. Guess I can hold off updating.
Thanks!
Users browsing this forum: No registered users and 61 guests
