It is currently Sun 24. Nov 2024 17:54:29
 Post subject: Telem KONTRONIK cable
PostPosted: Fri 13. Jul 2018 20:31:04
Hi How can I make the Telem KONTRONIK cable myself?
Gesendet von meinem SM-G950F mit Tapatalk
PostPosted: Sat 14. Jul 2018 11:16:55
The kontronik cable from the shop is the wrong one I think because it comes from the controller only signal and minus, otherwise I would order it
PostPosted: Sun 15. Jul 2018 15:46:49
you can't make it yourself unless you are electrical engineer and with possibility to crimp JST connectors. For this you will need very expensive tool.
Unfortunately I dont understand what is wrong. It is working for many pilots :)
Are you sure you need this cable? For Jive ESCs you need Telem UNI.
Users browsing this forum: Helihello and 66 guests
