Spirit System
Bluetooth Adapter and Power.
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2562
Author:  Rufus [ Mon 14. May 2018 14:05:58 ]
Post subject:  Bluetooth Adapter and Power.
Good day all...
I'm having a slight issue which has left me scratching my head.
My laptop was giving me some issues trying to setup Spirit fbl on one of my heli's and it's the laptops problem not the unit...anyways I decided to hookup the Bluetooth adapter to the unit and use my phone for the setup and to my surprise,the Bluetooth adapter uses the SYS and AUX ports on the spirit fbl.
My question is,now how do I power up the spirit fbl unit ? The ESC goes to the AUX port to power up the unit and now the Bluetooth adapter uses it.
Any idea or solution to this ? Want to find out first before I ruin the unit by powering it up through another port.I read the manual and you can't power it up through the SYS and ELE ports I believe.
Thanks for the help.
Sent from my SM-N910W8 using Tapatalk
Author:  ZeXx86 [ Mon 14. May 2018 16:07:57 ]
Post subject:  Re: Bluetooth Adapter and Power.
you can power it from any free powering port - either from receiver or from the unit.
For example AUX2, CH0 (Spirit Pro) or if you are using a standard receiver then from any port there.
Yes, ELE/PIT/AIL and SYS can't power the module.
Author:  Rufus [ Mon 14. May 2018 17:03:20 ]
Thanks Tomas,I'm using the regular spirit fbl.
Can I power it through the RUD port ?
The rest are all taken by servos and ESC (AUX).
Thanks.
Author:  ZeXx86 [ Mon 14. May 2018 20:05:46 ]
Yes, you can use RUD port with no problem.
Author:  Rufus [ Mon 14. May 2018 23:39:33 ]
Thank you,sir...[THUMBS UP SIGN]
http://www.phpbb.com/
