Spirit System
Hobbywing Platinum 130A HV V4 Connection
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2557
Author:  Michael [ Fri 11. May 2018 0:14:43 ]
Post subject:  Hobbywing Platinum 130A HV V4 Connection
I would appreciate some advice on connecting the following system.
Spirit Pro
Hobbywing Platinum 130A HV V4 (internal BEC)
SPM4649T Telemetry Receiver
SPM9645 Satellite Receiver
Installation is on a Trex 700 and my Tx is a DX9.
This is what I understand so far :
Spirit Pro
SYS
CH0
CH1 Pitch Servo
CH2 Elevator Servo
CH3 Aileron Servo
CH4 Rudder Servo
AUX2
AUX1 HW ESC Throttle Signal Cable
RUD Red/Brown wires to SPM4649T Bind/Serial port (using Jeti integration cable)
ELE/PIT/AIL Orange wire to SPM4649T Bind/Serial Port (using Jeti integration cable)
HW ESC
Programming Port connected to Spirit primary satellite port using Telem UNI cable
SPM9645 Satellite
Connect to secondary satellite port on the Spirit
Questions (if the above is correct) :
1) What do I do with the BEC Output cable (Red/Brown) from port -+R on the HW ESC (CH0 or Aux2 on the Spirit) ?
2) What do I do with the RPM Signal wire (Yellow) from port -+R on the HW ESC ?
3) Do I use the Laps/Volts/RPM port on the SPM4649T ?
Many thanks
Michael
Author:  ZeXx86 [ Fri 11. May 2018 12:30:22 ]
Post subject:  Re: Hobbywing Platinum 130A HV V4 Connection
your wiring seems to be correct.
1) AUX2 port or CH0 port can be used.
2) No need to connect it if Governor from the unit will be unused.
3) This depends on you. You can connect BEC voltage there - this will allow BEC voltage measurement.
Author:  Michael [ Fri 11. May 2018 20:55:44 ]
Many thanks for your help with this.
Author:  treys1 [ Fri 11. May 2018 21:48:26 ]
You can see here how I wire up to get RX voltage in the telemetry:
viewtopic.php?f=20&t=2385
Author:  Michael [ Sat 12. May 2018 2:19:38 ]
Thank you very much for sending me this
http://www.phpbb.com/
