It is currently Sun 24. Nov 2024 17:36:03
PostPosted: Tue 08. May 2018 8:55:20
Hello all together,
I flew yesterday with my TRex 550X (Spirit Pro, Setup mostly default settings).
Wind speed was approximately 25 km/h.
After or while a climb with full pitch I wanted to make a rudderturn to right side, but the heli did not or only very slowly react to the input. Left rudderturn was o.k.
I tried then rudderturns in both directions in normal pitch positions and all was o.k.
Is this “weakness” of right rudder a normal behavior because of the torque of mainrotor or have I to change my setup?
Thank´s in advance for every hint and with best regards
Roland
PostPosted: Tue 08. May 2018 9:05:17
this could happen, if the head speed is too low / rudder efficiency is too low.
If it is mechanical issue, you can only increase the RPM or use a longer tail blades.
If it is configuration related, then you can increase Pirouette Consistency by 10 - 20 points to make it better.
It depends on what RPM you are flying?
PostPosted: Tue 08. May 2018 9:53:06
Hello Tomas,
thank You very much for the quick reply.
Align offers für this Heli tail blades with 90 mm and 95 mm. I ´m the 95´s.
Head Speed RPM was 2000 rounds in Spirit Governor Mode.
I think, I will try to increase Pirouette Consistency and will give a feedback then
With best regards
Roland
PostPosted: Tue 08. May 2018 9:55:47
You can try to increase to 2200 - 2300 RPM. This should be optimal headpseed for this helicopter.
For 3D they are using even 2500.
PostPosted: Tue 08. May 2018 10:23:34
O.k, thank You.
I will try this too.
Users browsing this forum: Google [Bot], mainstreet and 66 guests
