spirit aero configure help https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2541 |
Page 1 of 1 |
Author: | hemraj [ Fri 27. Apr 2018 15:36:40 ] |
Post subject: | spirit aero configure help |
hi just installed a spirit aero I have setup the connections right as I start at the wizard the remote does not pass the signal in and there is no respond in the channel assign page plz advice |
Author: | ZeXx86 [ Sat 28. Apr 2018 9:52:24 ] |
Post subject: | Re: spirit aero configure help |
Hi, can you tell me what radio and receiver you are using? And how did you connected it together? If it is standard connection, then it is called PWM. For this connection 3 supplied cables are used. If connected properly it should work out of the box with no other changes in the unit. But if other connection is used, other receiver type must be configured (for example PPM, SRXL, SBUS, etc). You can also take a photo of your connection with receiver. Then I can help you more. |
