It is currently Sun 24. Nov 2024 14:48:07
PostPosted: Sat 03. Mar 2018 11:16:40
hi.ive been practising piro circles lately.can do both directions upright reasonably well and inverted clockwise.when i piro(particularly when inverted)it is not consistent.by that i mean it will spin 180 degrees at a certain speed,then spin quicker for the other 180 degrees,and so on and so on.i hope i make sense.just curious,is there settings to help tune this out?also i thought maybe its a centre of gravity (battery placement thing).thanks in advance for any suggestions/answers.
PostPosted: Sat 03. Mar 2018 11:22:41
exactly for this issue there is Pirouette Consistency parameter. You have to increase it. I guess by 10 - 20 points.
It is also possible, that if your head speed is too low, tail blade angle too small, rudder efficiency is also too low. So it is mechanically impossible to make it consistent.
So if increasing pirouette consistency will not help, you will probably need to increase head speed.
Users browsing this forum: No registered users and 57 guests
