SPirit pro setup https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2421 |
Page 1 of 1 |
Author: | flyingdockp [ Fri 09. Feb 2018 12:03:17 ] |
Post subject: | SPirit pro setup |
Hello, I want to use a spirit pro in a turbine helicopter, 3 blade (1.80m diameter) rotorhead, with a 4 point swashplate with a FRSKY receiver connected via SBUS (yes, this time with an ordinary cable ). Only thing is... the swashplate is rotated 45 degrees. How do I get this setup up correct in the Spirit Pro setup? Suggestions for initial setup? Thanks |
Author: | ZeXx86 [ Fri 09. Feb 2018 13:24:36 ] |
Post subject: | Re: SPirit pro setup |
You will have to use the CCPM 90 Velos swashplate type. Then set Advanced/Expert settings/Phase angle to 45° and it should work. |
