How to achieve asymmetric collective range for speed helis? https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2405 |
Page 1 of 1 |
Author: | curmudgeon [ Wed 31. Jan 2018 19:26:57 ] |
Post subject: | How to achieve asymmetric collective range for speed helis? |
I am trying to achieve a collective range of +16°/-10° pitch at high/low collective stick with 0° pitch at center stick. I can achieve this by several ways, but I am trying to figure out which way is best. One way is to set the collective range on the Spirit software so I get +16°/0°/-16° at high/mid/low stick and then adjust the pitch curve in the radio 0%-50%-100% to something like 21%-50%-100% Another way is to adjust the "Servo Travel Correction" on the Spirit software so I get less travel at low collective stick. I do not know how either method would affect the overall "resolution" and/or cyclic range deflection asymmetry. |
Author: | ZeXx86 [ Wed 31. Jan 2018 19:31:39 ] |
Post subject: | Re: How to achieve asymmetric collective range for speed hel |
Hello, the first method is correct. Usage of Servo Travel Correction is not a proper way, because it is not an assymetry of mechanics. So configuring it in your radio is right. |
Author: | curmudgeon [ Wed 31. Jan 2018 20:26:17 ] |
Great! Thank you |
