It is currently Sun 24. Nov 2024 14:50:21
 Post subject: SPirit pro setup
PostPosted: Fri 09. Feb 2018 12:03:17
I want to use a spirit pro in a turbine helicopter, 3 blade (1.80m diameter) rotorhead, with a 4 point swashplate with a FRSKY receiver connected via SBUS (yes, this time with an ordinary cable :D ).
Only thing is... the swashplate is rotated 45 degrees.
How do I get this setup up correct in the Spirit Pro setup? Suggestions for initial setup?
 Post subject: Re: SPirit pro setup
PostPosted: Fri 09. Feb 2018 13:24:36
You will have to use the CCPM 90 Velos swashplate type. Then set Advanced/Expert settings/Phase angle to 45° and it should work.
Users browsing this forum: mainstreet and 65 guests
