[SOLVED] Telemetrie Data with HOTT Integration https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2323 |
Page 1 of 1 |
Author: | rolandk [ Sat 02. Dec 2017 15:22:49 ] |
Post subject: | [SOLVED] Telemetrie Data with HOTT Integration |
Hello Tomas, I have a Graupner MZ24 with an assigned Smart Box, a Spirit Pro and Your Hott Integration Cable. I want now see telemetrie data like vibration level during flight. Do I need for that the Graupner General Air Modul or how can I do that with the Spirit Pro alone? In this respect I did not understand the manual to the HOTT Integration (programming the Spirit Pro via the MZ 24 transmitter works without any problem). Thanks in advance and with the best greetings Roland |
Author: | ZeXx86 [ Sat 02. Dec 2017 21:57:10 ] |
Post subject: | Re: Telemetrie Data with HOTT Integration |
Hello, if integration is already working then telemetry will work too. You only have to go to the main screen and there select Telemetry sensor you want. By default unit is emulating GAM sensor, so when you show GAM telemetry data, you will see all the telemetry values from unit. It is usually enough to press one button at the main screen of your transmitter to display telemetry. What telemetry values are there can be seen here: http://manual.spirit-system.com/index.p ... metry_data |
