Spirit System
[SOLVED] Current from a kontronik esc
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2291
Author:  icare [ Fri 03. Nov 2017 16:38:38 ]
Post subject:  [SOLVED] Current from a kontronik esc
Hi
here is a log of current in A for my diabolo. You can see that current in A freeze at the last value registered when I cut off the motor after few minutes.
Then when I start the motor again, the value is reset to the correct value. I don't know if it is a kontonik or a spirit telemetry bug ? (jive pro, spirit pro and jeti DS 14, no Telme). It is not very important, as consumed current is not affected.
Author:  ZeXx86 [ Fri 03. Nov 2017 16:46:16 ]
Post subject:  Re: Current with spirit and jeti telemetrey from a kontronik
this is "normal" behavior of Kontronik ESCs. But we can fix it in our unit :)
In next update it will be OK.
Thank you for the message.
Author:  icare [ Fri 03. Nov 2017 16:49:28 ]
:D
What can I say ??? Thank you for your support !
http://www.phpbb.com/
