It is currently Sun 24. Nov 2024 16:54:06
PostPosted: Thu 26. Apr 2018 16:35:05
Hello!
I use the spirit telemetry with a DS16. I connected the Spirit with the Telem Uni Cable with my Hobbywing 160.
But I do not get any data?
The problem is, I had previously connected a Hobbywing 130, because it worked!
Where could be the source of the error?
Frank
PostPosted: Thu 26. Apr 2018 16:50:29
your ESC is probably not updated.
Older firmware version does not support telemetry feature.
PostPosted: Thu 26. Apr 2018 16:59:59
Ok, it will update this evening!
PostPosted: Thu 26. Apr 2018 17:29:21
Update is on it.
Version 4.0.4 (Hobbywing) from 12.08.2017
Nevertheless, no data, only the temperature is displayed ...
The other values are zero.
Greeting
PostPosted: Thu 26. Apr 2018 19:17:30
According HobbyWing web page you need PL-04.0.06.
http://www.hobbywing.com/Upload/softwar ... icalTab_37
PostPosted: Thu 26. Apr 2018 21:05:42
Hi Tomas!
Even with the 4.0.06 i get no data.
Telem UNI Cable defekt?
PostPosted: Thu 26. Apr 2018 21:12:17
Are you sure you are connecting it in the correct Spektrum port?
Is the HobbyWing telemetry still enabled in the settings?
I guess the cable must be good if it worked with your other ESC.
Also we are testing each prior the shipping.
PostPosted: Thu 26. Apr 2018 21:18:33
I will rebuild the cable again in my TDF.
There it worked with the HW 130 yes in the TDF!
I will test tomorrow.
PostPosted: Sun 29. Apr 2018 16:21:17
Hello Tomas!
When building back I found a broken cable.
Do not ask me how that could be done :?:
Repaired, now it works fine again!
Greeting Frank
PostPosted: Sun 29. Apr 2018 21:39:03
Very well.
Thank you for your message!
Users browsing this forum: mainstreet and 30 guests
